Robert Koslover
        Certified Consultant
                                5 years ago
                                2020/12/29 14:38 GMT-5
                                                    You need to integrate your current density across a cross-sectional surface (presumably one normal to it).  There are a number of ways to do that.  If you don't already have that surface defined in your problem, you can add a 3D cut-plane.  You can do such integrals post-solving.  Go to Results --> Derived Values, right-click on that and choose Integration, then Surface Integration, then choose Cut Plane 1 from the Dataset pulldown under Data in the Settings panel.  Alternatively, you can also set up Probes that integrate quantities of interest over various surfaces that you specify.
