two phase flow using viscoelastic liquid
Hi, I want to model air-polymeric solution flow (two phase flow) using level-set method, but in two-phase laminar level set model how to incorporate the viscoelastic liquid as second phase?
2 Replies Last Post 2021/07/01 21:53 JST
Hello Banashree Samanta
Posted: 4 years ago 2021/02/11 2:30 JST
Hello
Can you give me the exact description of your problem. You may know that Level Set will be needing an initial interface for modeling.
Hello Can you give me the exact description of your problem. You may know that Level Set will be needing an initial interface for modeling.
Posted: 4 years ago 2021/07/01 21:53 JST
same problem. do you find a solution?
