2012/04/12 5:49 JST
which variable are you plotting (in solid the displacements are u,v,w and not x,y,z) could that be the point ?
The next item could be the excitation, do you have an excitation defined, with a non-zero amplitude ? (check the equations and your BCs)
Just a few guesses, not easy to say more ;)
2012/04/12 6:15 JST
Dear Ivar,
Thanks a lot for your quick reply! What you suggested regarding what I'm plotting could be the problem, although I thought of it already and tried my best to plot the right variables, but to no alas. What I've done:
1) indeed in solid mech. the displacements are in u, v, w, (i believe the problem to be here) but wherever I look I cannot find a possibility to plot u, v, or w on the y-axis. I've tried to plot everything from displacement field, displacement amplitude, material coordinate - all in Y direction - but all give weird results. The best sounding choice is "displacement field Y, u component" but also no real results are obtained. Is this sufficient or would you have an idea what I could try?
2) as regards the excitation with 0 amplitude : I have rigidly attached the left side of the beam and applied a downward force (-10 N) in the Y direction. (also tried higher forces) Then, for the frequency domain analysis I define a frequency range from (tried all possible combinations) 1:10:1000 Hz. With 'no function applied'. Have also tried applying a exp^10 from range(2,0.1,3) but nothing works. Should I apply a sin? What range should be used then (again: tried many combinations already).
Would you have any idea where I'm going wrong? All I want for this simple model (so I can move on with the hard part) is a graph showing resonance peaks. I manually calculated the first eigenfrequency to be around 18.000 Hz but don't see anything happening around the higher frequencies either.
Thanks so much for your help.
I have attached my model. THE ATTACH FILE BUTTON FAILS, SORRY
Henk de Winter
Dear Ivar,
Henk de Winter
2012/04/12 6:18 JST
Dear Ivar,
I have attached my model. ; I tried to attach it but the button fails
Henk de Winter
[QUOTE]
Dear Ivar,
Henk de Winter
[/QUOTE]
2012/07/17 22:24 JST
hey have u been able to solve ur problem?
2012/07/18 17:50 JST
Hey, no unfortunately, I have not received any response and am still stuck.
Regards, Henk
Regards, Henk
2012/07/19 14:49 JST
have you really tried a search on the FORUM, the model library and the model exchange ? I'm sure this has been discussed a few times and that there are models around here
2012/07/20 6:18 JST
Can you share your model, may be then we can look at it and get a better understanding as to why you are having this problem.
-Sankha
-Sankha
