Magnus Ringh
COMSOL Employee
4 years ago
2021/03/03 23:06 JST
Hi Amartya,
This error occurs because you are using the optional third argument to the realdot
operator in in an unintended way. From the COMSOL Multiphysics documentation:
realdot(a,b,jaclevel)
The jaclevel
argument controls Jacobian contributions of the realdot(a,b)
operator and can have the following values:
- −1: (default) Jacobian contributions in the assembling only if splitting of complex variables in real and imaginary part is active for the Study
- 0: no Jacobian contributions
- 1: always Jacobian contributions
In your model, you have defined the variable nEz
as intop1(realdot(emw.Ez,emw.Ez,emw.Ez))/A
, which is an incorrect use of the syntax with three input arguments.
Magnus Ringh
Hi Amartya,
This error occurs because you are using the optional third argument to the `realdot` operator in in an unintended way. From the COMSOL Multiphysics documentation:
`realdot(a,b,jaclevel)`
The `jaclevel` argument controls Jacobian contributions of the `realdot(a,b)` operator and can have the following values:
* −1: (default) Jacobian contributions in the assembling only if splitting of complex variables in real and imaginary part is active for the Study
* 0: no Jacobian contributions
* 1: always Jacobian contributions
In your model, you have defined the variable `nEz` as `intop1(realdot(emw.Ez,emw.Ez,emw.Ez))/A`, which is an incorrect use of the syntax with three input arguments.
Magnus Ringh
