2-D Axisymmetric Heat Source
Posted 2012/05/01 0:09 JST Fluid & Heat, Heat Transfer & Phase Change Version 4.2a 3 Replies
I am trying to define a cylinder which contains liquid that is generating heat from fission. I am using the Non-Isothermal Flow package as I will also be simulating natural convection from temperature gradients. The model is being set up in a 2-D axisymmetric system, so I am only describing half of the cylinder with the symmetry plane cut axially through the cylinder.
I am defining this heat generation using Heat Source (Q) in Watts/m^3.
In reality, the container holds 15 litres and is generating an overall heat of 20,000 Watts. This means an average generation of 1.33*10^6 Watts/m^3.
When inputting this into a 2-D axisymmetric model, will this average heat generation value reflect the overall 20,000 watts of heat generation? I have the model running, I am just not sure if the heat generation is correct and wanted to make sure that using a 2-D model can comprehend the watts/volume heat generation term.
Thank you for any help!
3 Replies Last Post 2012/05/06 12:16 JST
