To check whether a variable is an integer?
Is it possible to check whether the value of the variable at a particular timestep is an integer? Is there any function that I can use to find this?
Thanks.
5 Replies Last Post 2012/05/06 20:16 JST
Posted: 1 decade ago 2012/05/03 6:25 JST
never hear of that, but perhaps something like ((x-floor(x))<eps) might work, but check carefully the positive and negative side effects, and you ight need several times of "eps" if x is getting large
Hi never hear of that, but perhaps something like ((x-floor(x))
Posted: 1 decade ago 2012/05/03 6:34 JST
Possibly, we could use the 'mod' function i.e.
If mod(var,1) == 0 , it is an integer;
If you use matlab scripting 'isinteger' function could be used.
Possibly, we could use the 'mod' function i.e. If mod(var,1) == 0 , it is an integer; If you use matlab scripting 'isinteger' function could be used.
Posted: 1 decade ago 2012/05/03 16:05 JST
but what about the numerical precision ? in "automatic" mode COMSOL might stop and solve for a value very close to the integer, but not exactly "on" it
Hi but what about the numerical precision ? in "automatic" mode COMSOL might stop and solve for a value very close to the integer, but not exactly "on" it -- Good luck Ivar
Posted: 1 decade ago 2012/05/03 23:02 JST
Yes, we need to use some threshold (eps) as Ivar suggested in last post.
Posted: 1 decade ago 2012/05/06 20:16 JST
Thanks Ivar and Mranal. I used (ceil(t)-t<eps) and it works well. Thanks for your input.
