Names not consistent with number of parameter lists
Posted 2021/03/09 5:05 GMT-5 Simulation Apps, Equation-Based Modeling 0 Replies
I am trying to create a parametric sweep in the application builder. The aforementioned error appears as a consequence of the following line of code:
*model.sol("sol1").feature("s1").feature("p1").set("plistarr", temp); *
temp is a String[] variable that I have defined. The following line of code however seems work:
model.sol("sol1").feature("s1").feature("p1")..set("plistarr", new String[]{"30000 60000 90000 120000 150000 180000 210000 240000 270000 300000"});
In this regard, I tried to define temp as shown below, but I get an indication stating that "Array constants can only be used in initializers".
temp={"30000 60000 90000 120000 150000 180000 210000 240000 270000 300000"};
I have no experience in working with java and hence, I would appreciate it if someone could help me resolve this error.
Hello Prakyath Pindi Nataraj
