Difference Solution with the same model
Posted 2021/03/10 8:26 JST 1 Reply
I have run the model in frequency domain, radio frequency module with 2 sets of model parameters.
Case1: If I run data set1 directly, I can get one solution. Case2: However, if I run the model with data set2 before I run it with set1. The solution I got for set1 is different from case1. I have already clear all solution, delete the study and add the new one, compact history. The result still remain the same.
The reason I ask for this because I want to operate my problem in livelink to matlab. So, I have matlab code to generate differnt sets of model parameters and command comsol to run in loops. I don't know whether the previous run on the same model may affect the next run or not.
Thank you
