2012/05/09 15:01 GMT-4
interesting question, even if I'm not sure I have fully catched your demand, there ;)
From my understanding COMSOL is only set up to integrate overa discretized coordinate(s) via a mesh structure, or to integrate "time".
So either you have a way to map (Definition Model Coupling or Mapping) your variable onto another single dimension that you discretize and integrate, but still "INF" is a bit far fetched, I suppose you will have to remain within a finite domain though, or you can perhaps map it over time ?
2012/05/09 17:58 GMT-4
The issue with this is that timeint is only available in the results portion, not the variables section of the model (where I need it to be to define my new variable). I would think the capability should be there if comsol can perform a time integral and timeint could be hacked to do this non-spatial integral.
For now I will use a less-than-desirable workaround for integrating variables, but will update this if I can find any better solutions.
2012/05/09 18:18 GMT-4
but a time integration you can obtain by defining a new dependent variable and get that integrated directly, see the knowledge base (try a search), but I'm not sure that is enough for your case
9 years ago
2016/03/29 10:21 GMT-4
Hi Nathan,
I know it is an old post but did you manage to find a better solution? I also need to do something similar.
Hitesh
Hi Nathan,
Hitesh
Walter Frei
COMSOL Employee
9 years ago
2016/03/30 16:35 GMT-4
You can use the integrate function. You would used the syntax:
integrate( f(n), n, n_min, n_max)
Note that this is a numerical integration, so you can't integrate to infinity, but often get close enough, so:
integrate(exp(-n),n,0,10) is a good approximation to the true value of an integral to infinity, for that function.
See also:
www.comsol.com/blogs/integrate-functions-without-knowing-limits-integral/
See also: www.comsol.com/blogs/integrate-functions-without-knowing-limits-integral/
