Undefined variable problem when calculating the Coil inductance using mf.LCoil_1
Hello, I am new to COMSOL. Recently, I am trying to calculate the inductance of a pair of close-loop Coils. However, I have this "undefined variable" problem when calculating the inductance using mf.LCoil_1. While in this example (https://www.comsol.com/model/self-inductance-and-mutual-inductance-of-a-single-conductor-and-a-helical-coil-12679) I found on the COMSOL website it seems fine to assume that variable?
1 Reply Last Post 2021/04/01 7:04 GMT-4
Posted: 5 years ago 2021/04/01 7:04 GMT-4
Michelle,
I added a frequency domain step (at 50 Hz) to your model and this makes the inductance variables available. I am a little surprised as well that this is required, because inductance can in principle also be determined in a DC case. But on the other hand induction is not actually 'happening' in a way that could be measured. Make sure you add a small conductivity (e.g. 1 S/m) to the air domain, otherwise the frequency solver may not converge. For more accurate results you may also want to add infinite element domains around the air domain.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Michelle, I added a frequency domain step (at 50 Hz) to your model and this makes the inductance variables available. I am a little surprised as well that this is required, because inductance can in principle also be determined in a DC case. But on the other hand induction is not actually 'happening' in a way that could be measured. Make sure you add a small conductivity (e.g. 1 S/m) to the air domain, otherwise the frequency solver may not converge. For more accurate results you may also want to add infinite element domains around the air domain. Cheers Edgar
