2012/05/15 8:54 GMT-4
It should be possible with COMSOl CAD unit, if you start with a 3D tube (difference of two cylinders) and then create an extrusion ellipsoidal cylinder (or just a classical cylinder) with a radial axis that you duplicate radially 4-6 times and along the cylinder axis. then take the difference of your tube and all elpsoidal cylinders
2012/05/15 9:49 GMT-4
OK thank you so very much Ivar.It's could be a good solution, i'm trying just now. Only just one another question: after having built the single cylinders to realize radially in my tube , how can i duplicate radially 5-6 times my cylinder before doing difference?
Thanks so much!
Thanks so much!
2012/05/15 9:51 GMT-4
you have the copy or the move using the keep initial and you define a range or a comma separated series of values, this will duplicate it "n" times
10 years ago
2015/11/24 7:31 GMT-5
hi. Teach me show in video stent
Walter Frei
COMSOL Employee
10 years ago
2015/11/24 8:37 GMT-5
It is also worth mentioning that the Design Module:
www.comsol.com/design-module
has extended functionality for creating complex parts. In particular, the fillet and loft functionality may be useful to you.
http://www.comsol.com/design-module
