Robert Koslover
Certified Consultant
5 years ago
2021/04/14 11:05 GMT-4
Are you sure that the net space charge density is actually being computed in the way you described? (I, for one, would not attempt to code it that way.) See https://www.comsol.com/semiconductor-module for more info.
Are you *sure* that the *net* space charge density is actually being computed in the way you described? (I, for one, would not attempt to code it that way.) See https://www.comsol.com/semiconductor-module for more info.
5 years ago
2021/04/14 14:06 GMT-4
That is what they write in the documentation and how it is evaluated in the model so when plottet it gives a limited "dynamic range".
However, looking at the equation view in more detail it looks like the space charge density itself is actually not used for the further calculations so it is just computed for plotting. In that case things make sense.
5 years ago
2021/04/14 22:31 GMT-4
Often (usually?) the semiconductor equations are formulated in terms of the quasi-Fermi levels, not the charge densities.
I don't have the semiconductor module, but you can see what variables Comsol solves for by looking under Solver Configurations > Solution > Dependent Variables. All other quantities will be computed from these variables.
4 years ago
2021/04/18 18:25 GMT-4
I am using the quasifermilevel formulation but that doesn't change the problem of evaluating Poissons equation.
