More domains generated once elements exceed 32 by 32
Dear all,
I am modeling a panel with 40 by 40 holes. I use Block to get the 3D panel, and use Cylinder and Array to get 40 by 40 cylinders in the panel. But when I define the material properties of the solids, I found one more block solid was generated automatically. I try many times and find that once the numbers of the cylinders exceeds 32 by 32, the unexpected solid domain was then appeared. Therefore, I can not mesh the object once more.
Are there somebody faced this problem before?
I use COMSOL 4.2, this problem bother me for several days, I am looking forward to get help to this.
Thank you very much!
Baofeng
2 Replies Last Post 2012/05/18 4:55 JST
Posted: 1 decade ago 2012/05/18 4:31 JST
that sounds strange, I would say it's worth to ask directly "support", as as you suggest it could be some pointer size overrun issues but 32x32 = 2^5*2^5=2^10 << 2^15 ;)
Hi that sounds strange, I would say it's worth to ask directly "support", as as you suggest it could be some pointer size overrun issues but 32x32 = 2^5*2^5=2^10
Posted: 1 decade ago 2012/05/18 4:55 JST
to get 40x40 try doing 20x20 first, then union and another array of 2x2
