2012/05/30 22:33 JST
interesting, there are obviously some differences between the versions.
OK but have you tried to replace "0" in the axial direction by a "small" value, just to check it's really the anisotropy that is giving you problems and nothing else ?
2012/05/31 0:24 JST
Its the problem only with diffusion, I think.
I tried using very small value of diffusion coefficient like 1E-9 in axial direction. But in that case also, it is showing the same error. May be because then also peclet number is so large. Galerkin FEM is unstable for peclet greater than 1.
COMSOL 4.2a is able to solve the problem if I give diffusion coefficient in the axial direction as 1E-3 times that in transverse direction, but that is a big value for my problem.
But 3.5a is not showing any error and working properly.
How can I resolve this issue in 4.2a?
Seetha
Seetha
2012/05/31 0:59 JST
Please check the discretization and other artificial diffusion setting for variable 'conc' (convection-diffusion equation). I had similar issues, where solution for convection-diffusion equations were not matching for 3.5a (quad discretization) and 4.2 (linear discretization) version. If you make sure your discretization and other artificial diffusiuon settings are same, it should give same results. The documentation also contains more about artificial diffusion and other related settings.
Good luck.
Good luck.
2012/05/31 1:29 JST
Thanks for your reply.
I used the same settings of 3.5a.
In 3.5a, there was no need to add artificial diffusion, as the solution was non-oscillatory.
But 4.2a is not solving at all with zero or very small diffusion coefficient. Also I am already using very fine mesh, so if peclet needs to be less than one (if I use very small diffusion coefficient), then the mesh size should be very very fine one. But I am not sure, whether the problem is due to very high peclet or something else.
Seetha
Seetha
