Batch Mode Issue
Posted 2021/07/07 13:26 GMT-4 General, HPC & Cloud Computing, Studies & Solvers Version 5.6 1 Reply
Hello, I am trying to figure out how to use the Batch Mode command on my computer. I have read that you must enable the COMSOL commands by going to the advanced system settings and manually adding the "comsol bin executions" in the PATH settings. I believe I have done this step correctly, however, when I attempt to run a model with the command "comsolbatch" in the command prompt window I recieve an error stating that "comsolbatch is not recongized as an external or internal command, operable program or batch file. Why is this command not working? Is there a step I am missing when allowing the Path function?
Thank you in advance
