r=0 singularity in using axisymmetric PDE mode
I understand in pde mode nabla operator differs that in other modules for 2D axisymmetry. When I try to model diffusion in general PDE/coefficient PDE/classical PDE, COMSOL cannot handle the singularity at r =0 very well:
d(p,t)+d(d(p,r),r)+d(d(p,z),z)==-1/r*d(p,r)
r*d(p,t)+d(r*d(p,r),r)++d(r*d(p,z),z)==0
both fail.
I wonder what to do?
1 Reply Last Post 2012/06/11 6:19 JST
Posted: 1 decade ago 2012/06/11 6:19 JST
there are several mathematical ways to avoid a singularity when intrgrating over a domain, either we integrate around it, but without going "onto" the singularity, or we remove the singularity by an appropriate variable change, then the inverse is applied to the results.
I assume that in PDE mode, nothing is done specifically, leaving the user choose his method. While for all or most physics 2D-axi, COMSOL has implemented these different mathematical means to get around the r=0 singularity.
Astoday I'm doing engineering developments, I trust COSMOL, and the scientists using it, that the 2D-axi mathematical formulation has been handled correctly. But certainly, if I had ben working on my PhD with COMSOL, I would have added a chapter on these methods to show I understand them and to prove they are correct.
I suppose one can get some good clues what is being done by analysing the physics equation view, and comparing to the PDE math equations view
Hi there are several mathematical ways to avoid a singularity when intrgrating over a domain, either we integrate around it, but without going "onto" the singularity, or we remove the singularity by an appropriate variable change, then the inverse is applied to the results. I assume that in PDE mode, nothing is done specifically, leaving the user choose his method. While for all or most physics 2D-axi, COMSOL has implemented these different mathematical means to get around the r=0 singularity. Astoday I'm doing engineering developments, I trust COSMOL, and the scientists using it, that the 2D-axi mathematical formulation has been handled correctly. But certainly, if I had ben working on my PhD with COMSOL, I would have added a chapter on these methods to show I understand them and to prove they are correct. I suppose one can get some good clues what is being done by analysing the physics equation view, and comparing to the PDE math equations view -- Good luck Ivar
