global equations
There's a comsol model with 1 module with unknown u and there's another unknown v satisfying an equation f(u,v,a,b,c,d,...)=0, where u is the unknown solved by the module itself, f is defined in 'global expressions' and a~d... are parameters defined in 'global expressions'. In the 'global equations' interface, I set 'name' as v, 'equation' as f and 'initial' as v0. When solving it, an error message says: failed to evaluate u. What's wrong?
2 Replies Last Post 2021/09/15 12:12 JST
Jeff Hiller COMSOL Employee
Posted: 4 years ago 2021/09/13 23:39 JST
Updated: 4 years ago 2021/09/14 2:33 JST
Hello Carl,
You seem to have the same question as in this older thread and the same solution that Magnus provided in that thread should work for you as well. The short answer is that a Global Equation cannot contain terms that are spatially-dependent.
Jeff Hiller
Hello Carl, You seem to have the same question as in [this older thread](https://www.comsol.com/forum/thread/18590/a-gloabl-equation-problem?last=2011-05-23T20:35:26Z) and the same solution that Magnus provided in that thread should work for you as well. The short answer is that a Global Equation cannot contain terms that are spatially-dependent. Best, Jeff
Posted: 4 years ago 2021/09/15 12:12 JST
Thank you very much Jeff!
