Problem with Boundary Layer Meshes: Plane with rectangular gap as flow inlet boundary
Posted 2012/06/22 6:44 GMT-4 4 Replies
Hello Comsol Community
I have some major problems with my model, especially treating boundary layer meshes.
As you can see in the appended example-model, I've created 2 studies. one with BM meshes, one without.
Both cases are calculated with a extremely coase grid, I've also calculated both cases with finer grids. the difference in the results was just too big.
Example: Look at the 3D Cut Line, the pressure over the inlet boundary has to be the same. Thats the quantity I want to observe.
I think the problem is the geomtry of my model.
As you can see my flow inlet is the boundary in the middle of the geo, which is a box with a gap in the middle, where the fluid is coming out. since I wasn't able to create a rectangle in order to set the inlet, I just added the box in the middle, selecting only the lower boundary as inlet. But if I do so, I have big problem creating the BM meshes.
1. Somehow I have to select the inlet boundary also in the boundary mesh selection, otherwise I dont get the mesh lines. But BM meshes should also be inserted at the wall, so I am having a big problem.
The boundary 21 cant be deselected...
somehow if I have a plane with a gap in between which is the flow inlet, you cant use BM meshes!
What I am thinking of:
Increase the size of the rectangular box in the middle so that it goes a little bit into the wall (steel part).
then I can select the lower boundary as inlet. But then I would not get the same results as I have a pressure drop across the ''small inlet region.''
I would really appreciate your help.
4 Replies Last Post 2012/06/25 3:39 GMT-4
