I am getting following error
I have used the library model in microfluidics area with laminar flow level set application mode.
original example is made in Axial symmetry 2d space and i have made the geometry in simple 2D plane
Rest everything is kept same.
But it gives me the following error
Exception:
com.femlab.jni.FlNativeException: Expression could not be evaluated
Stack trace:
at solvermodel.cpp, row 1386, ()
at com.femlab.solver.FlSolver.femTime(Native Method)
at com.femlab.solver.FemTime.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
Can somebody help
Regards
Chattarbir Singh
1 Reply Last Post 2010/02/06 20:19 JST
Posted: 2 decades ago 2010/02/06 20:19 JST
in the part of your message the expression name not evaluated is not mentionned, it could be further up or down in the error log.
One cause is if you use library material data that depend on "T" and "p" (or other variables) and you do not solve for these, you must nevertheless define them, in this case adding a constant
T=20[degC]
p=1[atm]
generally helps
Other times it's the initial values left at "0" for T and p if solved for that causes some surprises.
I do not have access to my COMSOL licence these days so I cannot check your model.
Hi in the part of your message the expression name not evaluated is not mentionned, it could be further up or down in the error log. One cause is if you use library material data that depend on "T" and "p" (or other variables) and you do not solve for these, you must nevertheless define them, in this case adding a constant T=20[degC] p=1[atm] generally helps Other times it's the initial values left at "0" for T and p if solved for that causes some surprises. I do not have access to my COMSOL licence these days so I cannot check your model. Good luck Ivar
