Full width at half maximum plot
I am new to comsol and I am using 4.3. I would like to know how to mark the maximum value and half maximum along the y axis in a line graph. I would also like to draw the full width at half maximum. I would also want to extract the three and develop a table. I have attached the required file.Could anyone help me? Please!
2 Replies Last Post 2012/07/12 19:16 JST
Posted: 1 decade ago 2012/06/27 4:19 JST
interesting question, I'm not sure if it's that easy in COMSOL, certainly possible via Matlab or Java.
Within COMSOL you have the min() & max() operators for any variable (check the doc, they accept also a second argument, you need to search a bit deeper but its descirbed in the help)
For fields: min(V,x) returns the "x" coordinate of the minimum of the V(x,y,z,t) field, this work for the space coordinates, but I have never really tried for the time coordinate "t".
Now if you have defined a varibale my_var(t) and the max(my_var,t) returns the value for t, and defined
my_var_max = max(my_var(t)),
then you can define a
my_temp_var = my_var(t)*(my_var(t)< my_var_max / 2)
and search the max below and above the t_at_my_var_max.
There must be an easier way ;) but I cannot really identify it like, that within COMSOL
Hi interesting question, I'm not sure if it's that easy in COMSOL, certainly possible via Matlab or Java. Within COMSOL you have the min() & max() operators for any variable (check the doc, they accept also a second argument, you need to search a bit deeper but its descirbed in the help) For fields: min(V,x) returns the "x" coordinate of the minimum of the V(x,y,z,t) field, this work for the space coordinates, but I have never really tried for the time coordinate "t". Now if you have defined a varibale my_var(t) and the max(my_var,t) returns the value for t, and defined my_var_max = max(my_var(t)), then you can define a my_temp_var = my_var(t)*(my_var(t)< my_var_max / 2) and search the max below and above the t_at_my_var_max. There must be an easier way ;) but I cannot really identify it like, that within COMSOL -- Good luck Ivar
Posted: 1 decade ago 2012/07/12 19:16 JST
Thank you very much.
Melvin
Hi Thank you very much. Melvin
