Memory
I would like to make the calculation speed up. In order to do so, I installed memories (changed 2GB to 24GB) in my computer. But it looks like the speed did not change so much. I would appreciate it if you could tell me how to make the calculation speed up.
Is it pointless to install much memory to improve the calculation speed?
4 Replies Last Post 2012/07/04 6:18 JST
Posted: 1 decade ago 2012/06/28 23:05 JST
if you have a 64 bit OS there should be nothing to do. But not all models speed up that much, its particularly for larger ones. But you must also have a PC that can exchange data between the CPU and the RAM fast enough to really get a speed kick
Hi if you have a 64 bit OS there should be nothing to do. But not all models speed up that much, its particularly for larger ones. But you must also have a PC that can exchange data between the CPU and the RAM fast enough to really get a speed kick -- Good luck Ivar
Posted: 1 decade ago 2012/06/29 6:35 JST
Upgrade to faster CPU/more cores. Faster RAM also seems to help.
Posted: 1 decade ago 2012/07/04 6:16 JST
Thank you for your comment. I will try to check if my computer can do it or not. Because our license is NFL, I can use another computer which can communicate between CPU and RAM.
Thank you.
Thank you for your comment. I will try to check if my computer can do it or not. Because our license is NFL, I can use another computer which can communicate between CPU and RAM. Thank you.
Posted: 1 decade ago 2012/07/04 6:18 JST
Thank you for your comment. Because our license is NFL, I will look for suitable machine in our department too.
Thank you.
Thank you for your comment. Because our license is NFL, I will look for suitable machine in our department too. Thank you.
