HAM for multilayer
Posted 2021/10/20 3:44 GMT-4 Computational Fluid Dynamics (CFD), Heat Transfer Version 5.6 0 Replies
Hello everybody,
I want to perform an HAM 2D simulation through a multilayer wall with one sides a metallic structures, porous insulation and most importantly an air channel in between. Since I would like to have, on the HAM sides, only one domain so that I only have to couple the flow physic with the heat and moisture transport physics, my question is if it's better to use as main physic the one relative to Heat and Moisture transfer in air (and use the Building Material node within) or the Heat and Moisture transfer in Building material (and use the Moist Air node within).
Thanks in advance
Hello Daniele Usai
