Ball Moving Causing Stokes Flow in Viscous Fluid
Posted 2021/10/29 6:18 JST Structural & Acoustics, Fluid & Heat Version 5.6 3 Replies
I am trying to use the Fluid Structire Interface (FSI) Module to have a ball moving in an otherwise stationary fluid without using the phase field or level set activation.
My doimain is big, 1000 high and a 500km radius and the ball has a radius of 50km and is located 300km below the surface which is an open boundary. The fluid that the ball is in is very visous (1E19[Pa*s]). The velocity of the ball is only in the z direction and is on the order of magnitude of E-8 [m/s].
Where I am running into problems is with initial conditions convergence (which seems to be a comon problem) but I am not sure how to solve it. I have tried using a ramp function but do not know how to couple it to the time. I am hesitant to lower convergence tolerance.
So my question: How to get initail conditions for a system where structure causing a fluid to move from rest?
