Internal error in geometry composition, Comsol 4.2a
Dear Fellows,
I want to make blocks with round edges in 3D. I use standard procedure, I define workplanes, make geometrical objects in 2D, do "extrude", end on the end - INTERSECTION.
When I do these steps in Comsol 4.2a version 4.2.1.110 (older version) everything is OK, but when I do the same in
Comsol 4.2a version 4.2.1.166 (newer version) I receive message:
"Internal error in geometry composition"
Please if someone have a solution for this problem because I need to solve this in newer version because on workstation on which I work is the newer Comsol. I tried to make this module in older version and then to open it in newre version, but then I receive some message about problems with CAD import module.
Thanks in advanced.
1 Reply Last Post 2012/08/16 19:46 JST
Hello Nikola Bralovic
Posted: 1 decade ago 2012/08/16 19:46 JST
this error often means that the programm doesnt like certain boundaries to touch/overlap with each other. just create a minimal gap between each geometric object to get it to work and then search stepwhise for the bugged area by removing the gaps one at a time
