Henrik Sönnerlind
COMSOL Employee
4 years ago
2021/11/22 17:53 JST
Updated:
4 years ago
In the weak contribution, one term is
. This means that
must adapt so that the thickness direction stress is zero (in the weak sense).
Henrik Sönnerlind
COMSOL
In the weak contribution, one term is \sigma_z \cdot \mathrm{test}(\epsilon_z) . This means that \epsilon_z must adapt so that the thickness direction stress is zero (in the weak sense).
4 years ago
2021/11/23 19:21 JST
That's what I expected but I never saw this in equation view in any version higher than 5, why?
4 years ago
2021/12/08 17:13 JST
When plane stress is chosen, there seems to be no constraint on the z stress in its strong or weak form, why?
Henrik Sönnerlind
COMSOL Employee
4 years ago
2021/12/09 22:35 JST
The weak equation reads:
(-solid.Sl11*test(solid.el11)-2*solid.Sl12*test(solid.el12)-2*solid.Sl13*test(solid.el13)-solid.Sl22*test(solid.el22)-2*solid.Sl23*test(solid.el23)-solid.Sl33*test(solid.el33))*solid.d
Now, if you look in Equation View, you will find that solid.el33 is equal to the auxiliary degree of freedom wZ, representing the strain in the transverse direction. This DOF will then be adjusted so that the transverse stress solid.Sl33 is forced to be zero (in a weak sense).
Henrik Sönnerlind
COMSOL
(-solid.Sl11\*test(solid.el11)-2\*solid.Sl12\*test(solid.el12)-2\*solid.Sl13\*test(solid.el13)-solid.Sl22\*test(solid.el22)-2\*solid.Sl23\*test(solid.el23)-solid.Sl33\*test(solid.el33))\*solid.d
Now, if you look in *Equation View*, you will find that solid.el33 is equal to the auxiliary degree of freedom wZ, representing the strain in the transverse direction. This DOF will then be adjusted so that the transverse stress solid.Sl33 is forced to be zero (in a weak sense).
4 years ago
2021/12/20 17:52 JST
Updated:
4 years ago
Thank you very much Dr Sönnerlind.
