2012/07/10 11:57 JST
Dear Mr.
which version of comsol u use
Dear Mr.
2012/07/11 0:15 JST
i use 4.2 version
thanks
i use 4.2 version
thanks
Nagi Elabbasi
Facebook Reality Labs
2012/07/11 0:24 JST
Hi Vishal,
If the number of solid particles is significant enough to affect the fluid or thermal properties consider using a multiphase mixture model. If not consider solving the fluid-thermal problem first then adding the solid particles using the particle tracing module.
Nagi Elabbasi
Veryst Engineering
Hi Vishal,
Nagi Elabbasi
Veryst Engineering
2012/07/11 0:29 JST
Actually i have to model a pipe line with fluid flow having solid particle which affect the properties under high temp /flux,please tell me which different physics i should use to accomplish this ,i have used laminar flow,heat transfer in fluids till now.
2012/07/11 0:32 JST
If you have any good tutorial related to this model please provide me ,
Nagi Elabbasi
2012/07/11 0:34 JST
Change the laminar fluid model to laminar multiphase flow. There are different choices in COMSOL for multiphase flow. Based on what you described I suggest using the mixture model. COMSOL gives it the name Mixture Model, Laminar Flow (mm).
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
2012/07/11 0:37 JST
Thanks for the help i will let u know if there is any problem,
2012/07/11 1:02 JST
while using multiphase mixing model ,what i did i used 2d axisymmetric geometry and i want to use water with some sand particle in pipe,so i have selected water and sand as material but i dont know how to select domain for these two materials ,as i have only 1 domain ,i have given the inlet condition as velocity and outlet -pressure,
Please tell me how to resolve this issue, and if u want i can attach my model file.
please let me know
please let me know
2012/07/11 1:34 JST
i have resolved the domain problem .but if there is any way to visualize the solid particle in the flow
2012/07/11 1:38 JST
can u provide me a good tutorial related to this,
Nagi Elabbasi
2012/07/11 1:47 JST
No I don’t think you can visualize individual particles using this method. There is a volume fraction variable that tracks the volume fraction of the dispersed field which in your case is the solid particles. There are several examples in the model gallery on multiphase flow that are very informative.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
2012/07/11 1:48 JST
okay i will try wid that .
thanks
thanks
2012/07/12 1:46 JST
Hi, please tell me how to use particle tracing in my case ?
thanks.
thanks.
2012/07/13 0:23 JST
i am using multiphase mixing laminar model to model silica sand particles in water in a pipe,but i want to know that how i can change the mixing fraction of silica sand for various case,i am interested in velocity and temp profile,Pleae help.
2012/07/17 6:45 JST
