Magnus Ringh
COMSOL Employee
3 years ago
2021/12/27 22:47 JST
Updated:
3 years ago
Hi Susan,
For this purpose, use an Interpolation node under the Component>Definitions node, where you can import the heat transfer coefficient h as a text file with four columns in 3D: on each row, the correspoding x, y, and z coordinates and the value of the heat transfer coefficient at that point. You can give the interpolated function a descriptive name, such as h_interp
, and also select the Use spatial coordinates as arguments check box, so that you can use h_interp(x,y,z)
in the text field for the heat transfer coefficient in the heat transfer physics interface. Also define units for the function (W/(m^2*K)
) and the arguments (m
) to avoid unit warnings. You can also try the settings for Interpolation and Extrapolation in the Settings window for the Interpolation node and plot the interpolated data to make sure that it looks as expected.
Magnus
Hi Susan,
For this purpose, use an **Interpolation** node under the **Component>Definitions** node, where you can import the heat transfer coefficient *h* as a text file with four columns in 3D: on each row, the correspoding x, y, and z coordinates and the value of the heat transfer coefficient at that point. You can give the interpolated function a descriptive name, such as `h_interp`, and also select the **Use spatial coordinates as arguments** check box, so that you can use `h_interp(x,y,z)` in the text field for the heat transfer coefficient in the heat transfer physics interface. Also define units for the function (`W/(m^2*K)`) and the arguments (`m`) to avoid unit warnings. You can also try the settings for **Interpolation and Extrapolation** in the Settings window for the **Interpolation** node and plot the interpolated data to make sure that it looks as expected.
Magnus
3 years ago
2021/12/29 16:36 JST
Hi Magnus,
Thank you so much for your help and detailed information.
The boundary where I will set h_interp(x,y,z) is a curve. Since the heat transfer coefficients is a function of arc length along the boundary h=f(s) and when I change h=f(s) to h=f(x,y,z) and import into COMSOL, I am not sure if the points are exactly on the boundary. How can I control this?
Thanks and Merry Christmas!
Best wishes,
Susan
Hi Magnus,
Best wishes,
Susan
Magnus Ringh
COMSOL Employee
3 years ago
2021/12/29 21:11 JST
Hi Susan,
With a curved boundary, it becomes more difficult. Perhaps you can make use of the curve parameter s
in 2D or the surface parameters s1
and s2
in 3D. For further assistance, please contact the COMSOL support team.
Magnus
Hi Susan,
With a curved boundary, it becomes more difficult. Perhaps you can make use of the curve parameter `s` in 2D or the surface parameters `s1` and `s2` in 3D. For further assistance, please contact the COMSOL support team.
Magnus
3 years ago
2021/12/30 11:08 JST
Hi Magnus,
Thank you. I will have a try.
It is difficult to understand s1 and s2, so I will first learn to use different kinds of coordinates.
Best wishes,
Susan
Hi Magnus,
Best wishes,
Susan
