Electric field amplitude from data set
Hello everyone,
I'm trying to transfer a wavefield I measured in one model to another model. I measured the field in the first model with a listener port and exported the data. Now I would like to give this information to an excitation port in a different model.
I already interpolated a function with the measured values in MATLAB and used this function as the electric mode field amplitude in the excitation port.
This worked quite well but is it also possible to give the numerical values directly to the excitation port?
Thanks for your help
Jesco
1 Reply Last Post 2022/01/28 13:35 JST
Posted: 3 years ago 2022/01/28 13:35 JST
Updated: 3 years ago 2022/01/28 13:36 JST
Hi Jesco
If you use "COMSOL's interpolation function" without using Matlab, you can use the exported data source as an input field as it is.
If you want to use complex amplitude, you can separate the real part and the imaginary part to generate two real-valued functions, and specify the complex amplitude using the two functions at the input port.
I'm not a Comsol advisor, so there may be an easy way to set up a complex interpolation function apart from this one.
Hi Jesco If you use "COMSOL's interpolation function" without using Matlab, you can use the exported data source as an input field as it is. If you want to use complex amplitude, you can separate the real part and the imaginary part to generate two real-valued functions, and specify the complex amplitude using the two functions at the input port. I'm not a Comsol advisor, so there may be an easy way to set up a complex interpolation function apart from this one.
