2012/07/13 7:14 JST
I think you should use another physical field. You can choose it from chemical engieering model........
2012/08/21 22:12 JST
Hi Melvin,
Were you able to solve the problem? I am also facing the same problem. Could you let me know the solution in case you were able to find a way out?
Thanks in advance,
Pankaj
Hi Melvin,
Thanks in advance,
Pankaj
2012/08/22 14:01 JST
I am not sure about your problem but you can try the CFD/ Multiphase flow/ two phase flow, level set. If you can post your model file, then we can know your problem better.
2012/08/23 6:23 JST
I tried the multiphase flow with level set but I am facing problem with the model. The solution does not seem to converge. I am attaching the model here. Could you let me know where am I going wrong?
2013/04/18 22:16 JST
Hi , I am facing the same problem now can you please give me a solution !
9 years ago
2016/07/19 14:16 JST
Hii,
I am working on comsol 5.0 on dehumidification model , and facing problem on mixing 2 fluids (water and moist air) on single domain.
please help me in selection of physics.
Hii,
8 years ago
2016/12/10 11:10 JST
hello
Has anyone here ever came to a solution for the problem.
Does a multi-componant mixing simulation (Water and Glycerin,for example) even possible in Comsol?
hello
8 years ago
2017/06/14 2:20 JST
Hi Gil,
Have you solved that problem of mixing two different fluids?
If you have then please upload that.
Hi Gil,
Walter Frei
COMSOL Employee
8 years ago
2017/06/15 3:16 JST
With regards to the general question about mixing of two dissimilar fluids, please see this article:
www.comsol.com/blogs/which-multiphase-flow-interface-should-i-use/
There does also seem to be a question about modeling of water and humid air, in which case these articles, and associated models, are helpful:
www.comsol.com/blogs/intro-to-modeling-evaporative-cooling/
www.comsol.com/blogs/how-to-model-heat-and-moisture-transport-in-air-with-comsol/
In addition, if the two fluids have similar properties, but carry different species, you may find this example useful:
www.comsol.com/model/split-and-recombine-mixer-benchmark-14031
Best Regards,
https://www.comsol.com/blogs/which-multiphase-flow-interface-should-i-use/
https://www.comsol.com/blogs/intro-to-modeling-evaporative-cooling/
https://www.comsol.com/blogs/how-to-model-heat-and-moisture-transport-in-air-with-comsol/
https://www.comsol.com/model/split-and-recombine-mixer-benchmark-14031
Best Regards,
