2012/07/17 18:25 JST
You need to define a step function and use it to multiply the inlet velocity so that the velocity goes from 0 to some value during the computation otherwise it will never manage to find correct initial values.
Cheers
Cheers
2012/07/21 10:15 JST
Thank you very much. I tried it out and it worked. Seems the inlet condition was indeed too steep for the software to handle. I smoothened it out with a step function as you suggested and now the simulation runs on transient mode.
One more thing, since the simulations are taking a lot of time to execute, is there any way I can limit the number of iterations or run-time for which the simulation will give me a set of results? I know I can limit the number of iterations or tolerance at the 'segregated step' in the solver node, but is there any other way to do that?
Thanks again.
Thanks again.
2012/07/21 17:14 JST
have you tried to run first a stationary solver case and then a transient. In this way you get really a good initial condition and your transent analysis will run smoother. Sometimes its better to start from a stationary high speed case and lower the inlet flow, than starting from "0", but you can also start from 10% or 50% of nominal inlet speed, in stationary, and then ramp up with a smooth step to 100% or whatever oscillatory conditions you want.
One thing if you start with a too slow flow, you are not really in a turbulent case, that might be an issue for your convergence
But, turbulent transient flow is something one mostly do on a cluster ;)
2012/08/31 4:06 JST
I have the same problem here while i am simulating flow through fixed bed reactor,porous media, my problem is i tried
multiplying the inlet velocity with "step1" but it says "unknown variable step1".
what should i do in defining the etep funcation? i just used the default
location 0
from 0
To 1
then i simply multiply it with inlet velocity profile but it displays the above error
regards
location 0
from 0
To 1
regards
