                                2012/07/17 1:27 GMT-4
I believe it was already implemented in 4.0 then you can export the data set with real(Ex) and imag(Ex), but real nad imaginary part separately as 2 scalars
                                2012/07/17 13:45 GMT-4
                                                    You might want to check the exported file manually. When I export imaginary data, it exports as the number followed immediately by 'i' without any spaces or other characters; e.g. 4.0023*i exports as '4.0023i'. Many automated import scripts would recognize this number as '4.0023' (truncating the 'i') and not as '4.0023*i'.
                                2012/07/17 13:54 GMT-4
                                                    Thank you Ivar,
Now I can obtain real and imaginary part separately.
                            Thank you Ivar,
                                2012/07/17 13:56 GMT-4
                                                    Thank you for your comment.
I imported it through Matlab and there was no "i" attached.  Thanks for noting that!!
                                2012/09/05 10:01 GMT-4
                                                    hi  how do you export the electric field from the mode solver? what i get has no imaginary part. can you tell me how to do that, looking forward to your reply!!thanks!
hualong
hualong
                                2012/09/05 10:25 GMT-4
                                                    can you tell me how you get the imaginary part of the electric field,looking forward form you. thank you!
                                2012/09/05 10:34 GMT-4
I used real() or imag() in the evaluation section to extract complex field components.
For instance, if you want to extract real and imaginary part of Ex field, use real(Ex) and imag(Ex).
                                2012/09/05 11:18 GMT-4
                                                    Hi Min,
first, many thanks!!
that means if want to extract the imaguinary data of Ex, the sentence i should write on comsol-matlab is following
yy=postplot(fem,'tridata',{'imag(Ey)','cont','internal','unit','V/m'},'solnum',index,'outtype','postdataonly');
then I can find my data in yy, is that right?
Br,
hualong
                            Hi Min,
Br,
hualong
