Measuring Flow rate in a well.
Posted 2022/02/01 16:25 JST Fluid & Heat, Porous Media Flow Version 5.6 0 Replies
i am simulating a geothermal doublet currently with Darcy flow only. The first task was simulating stimulation works.
I defined 2 wells by building 2 open curves. Under "Darcy's Law" i defined those open curves as "wells", assigned both wells "injector" and defined a function with a mass flow depending on time, which i entered in "mass flow rate".
The simulation went fine, the reservoir pressure behaved as expected. So far, so good.
Now, for controlling purposes i used under "derived values", the top points of both wells to give me the mass flow. For some reason i get exactly the same values for both of these points, even though they belong to different wells that were stimulated independent of each other.
So... how can i get an idea off the mass flow in each well? When one well gets stimulated, while the other is not used, there should be a positive mass flow (as a reaction to the pressure increase), and i want to see how much that is.
Any idea?
Hello Aron Gabriel
