Using Matrix Transform with Principal Strain Tensor For Principal Strains along Force Application Direction
I am running a solid mechanics study with a body load being applied with the total force load type option, defining values for Fx, Fy, and Fz. After running the study, I want to analyze the principal strains, but specifically along the direction of the applied body load, which here is along the unit vector (-0.91755, -0.35177, -0.18536).
My thought is that I can use the Matrix Transform function in COMSOL to transform the principal strain tensor so that one of the principal strain directions is now along the force application direction.
However, I am confused on how to use the Matrix Transform variable utility. I am assuming my input would be Component 1 --> Solid Mechanics --> Strain --> Strain tensor (material and geometry frames) --> solid.e. However, how do I then use this to transform to the wanted direction? I don't see any input for a transform option like inputting a transformation matrix. Any assistance would be helpful.
Note I am using Linux OS if that makes a difference
2 Replies Last Post 2022/03/01 22:32 JST
Jeff Hiller COMSOL Employee
Posted: 3 years ago 2022/03/01 6:29 JST
Hello Coleman,
I'll refer you to Henrik's post in your earlier thread. No amount of matrix manipulation can change the direction of principal strains.
Jeff Hiller
Hello Coleman, I'll refer you to Henrik's post in [your earlier thread](https://www.comsol.com/forum/thread/304112/finding-the-principal-strain-along-the-direction-of-the-force-applied?last=2022-02-17T21:48:42Z). No amount of matrix manipulation can change the direction of principal strains. Best, Jeff
Posted: 3 years ago 2022/03/01 22:32 JST
Hello Coleman,
Hi Jeff thanks for the answer! After not hearing back, I was hoping for some more information on implementing using the matrix transformation in accordance with the coordinate system corresponding to the force direction.
>Hello Coleman, > >I'll refer you to Henrik's post in [your earlier thread](https://www.comsol.com/forum/thread/304112/finding-the-principal-strain-along-the-direction-of-the-force-applied?last=2022-02-17T21:48:42Z). No amount of matrix manipulation can change the direction of principal strains. > >Best, > >Jeff Hi Jeff thanks for the answer! After not hearing back, I was hoping for some more information on implementing using the matrix transformation in accordance with the coordinate system corresponding to the force direction.
