2012/07/25 3:14 JST
Have you tried using 1D interpolation using text file for data input? Essentially, it's the same for 2D.
2012/07/25 8:33 JST
Yes, I am capable of doing the 1D interpolation and creating the function from that, however, I am having difficulty figuring out how to extend that to two parameters, such as a density that is a function of temperature and pressure and would be interpolated based on both of their values.
2012/07/25 8:59 JST
1. create data file with 3 columns: P,T,f(P,T)
2. define interpolation function (say int1), use data from the file
3. make sure you defined the int. function correctly. Just click the "plot" button to plot it
4. now you can use the function int1(P,T) to define material properties. Just make sure to fix the units for P and T so the text field appears in black, not in red or yellow color.
2012/08/01 1:58 JST
HI,
Could you please expand on the properly defining the function int1? I have uploaded data with three columns the first column is Temperature the second column is pressure and the third is the density as as a function of the two.
Should the data for sure be in columns? and should there be column headings in the data file?
Would it be possible for you to send me a quick screenshot of how you have set up a 2D interpolation? It would be great help because I feel like I am doing everything you have stated but I am getting numerous errors related to improper number of functions and arguments, etc.
Thanks.
Chris
HI,
Thanks.
Chris
2013/02/12 0:08 JST
Have you succeeded to creat 1D interpolation?
I have some problems about how to create interpolation function on temperature-dependent thermal conductivity. I have made a .txt file with two columns (the first column is the Temperature, and the second one is thermal conductivity).
But i have no idea how to insert the text into Material Contents. I typed the function name in the blank of "Value", but the font color is always yellow. It always comes out as "The following feature has encountered a problem: Failed to evaluate variable Jacobian....."
Do you know why this happened?
2013/02/12 4:40 JST
In the Value field, you need to write the function with the argument: my_function(my_variable).
2015/03/03 17:29 JST
Thanks. Very helpful tips.
[QUOTE]
[/QUOTE]
