Automatize the ''initial conditions from previous solution'' process
I have a time-dependent study. I would like to do the following:
-Solve the system from time t0 to t1.
-Change the value of a material property.
-Solve the system from t1 to t2 using previous solution as initial condition at t1 and new value of material property.
-Change the material property again, etc...
I have the solution from t0 to t1 attached to solver1. If I create a solver2 with an inital condition from solver1 and run a parametric sweep for the material variable, then all the runs will take initial conditions from t1 (which is not what I want). Is there a way to make sweep 1 take IC from t1, sweep 2 take it from t2 (last value of sweep 1), etc... ?
This is easily done manually but I was wondering whether or not this process could be automatized. A previous post mentioned it could be done but didn't explain how.
Thank you very much,
Dmitri
0 Replies Last Post 2012/07/24 7:25 GMT-4
Hello Dmitri Hennion
