How do i apply Ground in "Magnetic Fields (mf)" physics package?
Hello together, I want to simulate a coil system in Comsol. I used the "Magnetic and Electric Fields (mef)" physics package and could easily apply a ground boundary there (frequency domain). Now I want to solve the system in time domain, which is only possible in the "Magnetic Fields" physics, but I can't find a ground boundary there. How can I apply it?
3 Replies Last Post 2022/03/28 22:29 JST
Posted: 3 years ago 2022/03/25 20:12 JST
Hendrik,
in mf you cannot apply an electric potential boundary condition, so ground is not an option.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hendrik, in mf you cannot apply an electric potential boundary condition, so ground is not an option. Cheers Edgar
Posted: 3 years ago 2022/03/28 21:52 JST
Hi Edgar,
thank you for the reply. Alright.
I simply want to simulate a piece of conductor with 2 coils around it. I can easily define a current through the coils via the option "coil", but I also want to define a current through the piece of conductor. In the mef-package I could do it with a terminal on one side and ground on the other. Do you know how I can apply a current in the piece of conductor in the mf package?
Thank you and kind regards, Hendrik
Hi Edgar, thank you for the reply. Alright. I simply want to simulate a piece of conductor with 2 coils around it. I can easily define a current through the coils via the option "coil", but I also want to define a current through the piece of conductor. In the mef-package I could do it with a terminal on one side and ground on the other. Do you know how I can apply a current in the piece of conductor in the mf package? Thank you and kind regards, Hendrik
Posted: 3 years ago 2022/03/28 22:29 JST
Hendrik,
you can use the piece of metal as a coil as well. A coil in Comsol doesn't need to look like a typical helical coil. Also it doesn't need to be a closed loop if you guide the terminal ends to an outside boundary of the model. Check the documentation about the requirements for coils.
Cheers Edgar
Edgar J. Kaiser
www.emphys.com
Hendrik, you can use the piece of metal as a coil as well. A coil in Comsol doesn't need to look like a typical helical coil. Also it doesn't need to be a closed loop if you guide the terminal ends to an outside boundary of the model. Check the documentation about the requirements for coils. Cheers Edgar
