Pressure Acoustic, boundary element interface
Posted 2022/03/30 8:32 GMT-4 Acoustics & Vibrations Version 5.6 6 Replies
hello,everyone! I had already simulated the sound propagation issues in free space and semispace by comsol Pressure Acoustic boundary element interface,but now I was having problem simulating the same sound propagation issues in a layered waveguide(just like the ocean waveguide),because I can only set just one symmetric/infinite sound hard or antisymmetric/infinite sound soft boundary in one direction, that is to say I could only set the water surface as a antisymmetric/infinite sound soft boundary or set the bottom as a symmetric/infinite sound rigid boundary, but actually I need both of them. Is there any way to make it possible by Pressure Acoustic(BEI)? Any reply will be helpful,thanks all.
It is unclear why you at the same time want symmetry and anti-symmetry at a boundary.
-------------------René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Dear sir, Maybe I didn't make my statement very clear. For example,what I want is to have a anti-symmetry boundary at z=0 and a symmetry boundary at z=z0, you know just like the sea level and the bottom. Or a symmetry boundary at z=0 and a symmetry boundary at z=z0 to simulate roof and floor of a room separately.
Ah okay. The symmetry conditions presumably alters the Green's function in the underlying integral equation to take into account the mirror source(s), but to get the additional plane you would probably need to have some explicit geometry with the desired boundary conditions. Perhaps there is a more elegant way to do it, but it depends on your application. But it sounds more like an interior problem, so perhaps FEM instead of BEM is better option for you anyway.
Acculution ApS
www.acculution.com
info@acculution.com
Thanks for your reply
Thanks for your reply. Exactly it sound likes an interior problem and I have already tried FEM in the beginning, but the geometric scale and frequency range that I want to study is quite large and therefore you know FEM takes lots of memory and time to solve the problem so I switch my sight to BEM for a way. At last,thanks for your advice.
You can of course also do interior BEM but perhaps you should sketch your problem or upload the file
Acculution ApS
www.acculution.com
info@acculution.com
Suggested Content
- FORUM Pressure Acoustic Boundary Condition Problem
- FORUM Fluid models in pressure acoustic interface
- BLOG Introduction to Modeling Acoustic-Structure Interactions in COMSOL®
- KNOWLEDGE BASE Error: Failed to Find a Solution. Returned Solution is Not Converged
- KNOWLEDGE BASE Two-Phase Flow Modeling Guidelines
