How to draw time derivative of temperature in result
I have results computed using Time Dependent solver. It is cooling of 3D plate. I can create 3D Plot for temperature. Is it possible to show reults for cooling rate which is time derivative of temperature? How? I tried this in expression: d(T,t) but Comsol says: Time derivative only allowed with respect to mesh time.
2 Replies Last Post 2022/04/06 9:11 GMT-4
Posted: 4 years ago 2022/04/06 9:06 GMT-4
mesh.dt(T)
mesh.dt(T)
Magnus Ringh COMSOL Employee
Posted: 4 years ago 2022/04/06 9:11 GMT-4
Updated: 4 years ago 2022/04/06 9:12 GMT-4
I'm not sure if d(T,t) (or Tt) would work in version 6.0; it does in a simple heat transfer model that I just tested. But if you want to use a derivate with respect to mesh time, use d(T,TIME) or mesh.dt(T). It could be the case in a model that uses an ALE (algebraic Lagrangian-Eulerian) formulation, for example.
Magnus
Hi, I'm not sure if `d(T,t)` (or `Tt`) would work in version 6.0; it does in a simple heat transfer model that I just tested. But if you want to use a derivate with respect to mesh time, use `d(T,TIME)` or `mesh.dt(T)`. It could be the case in a model that uses an ALE (algebraic Lagrangian-Eulerian) formulation, for example. Best regards, Magnus
