Exporting simulation end time in Parametric study
Posted 2022/04/07 9:34 GMT-4 General, Heat Transfer Version 6.0 0 Replies
My 2D heat transfer study is transient and the simulation stops when a particular boundary reaches desired temperature or it will run until the specified end time (eg: 100 steps).
If the stopping criteria is satisfied at 60 steps, how do I print or export this time-step number? Currently, I created a time vs temperature 1D plot and I am copying the table data to excel manually to check the last time step value.
I should be able implement the same in paramteric study such that my output table will have 2 columns. First column with paramter combination details and second column with last time step value for the corresponding combination.
Additionally, I also want to export the above mentioned 1D plot that shows the time vs temperature for each combination in the paramteric study.
Thank you.
Best Regards, Saketh Bharadwaj
Hello Polina Pirch
