Bidirectional coupling between metal powder particles and fluid temperature field
Posted 2022/04/11 8:23 GMT-4 Fluid & Heat, Heat Transfer, Particle Tracing for Fluid Flow 0 Replies
Dear friends, hello! I need your help badly.
1.Description of physical model: Heat molten metal powder particles by RF inductively coupled plasma. I mainly simulates the heating process of powder particles and the influence of powder particles on the physical quantity of flow field.
- At present, there are two models in COMSOL: one is bidirectional coupling between powder particles and flow field; The other is the unidirectional coupling between powder particles and fluid temperature field. Neither of these two models can realize bidirectional coupling of powder particles with temperature field and flow field simultaneously.
3.My main problem is: how to realize the bidirectional coupling between the powder particles of the discrete phase and the temperature field of the continuous phase in the fluid, and how to combine these two physical models.I would appreciate your advice.
Hello 景奇 白
