Plotting experimental points in COMSOL
I am trying to plot the experimental points in the cross sectional plot parameter domain. As i have ploted the simulation results in this domain.
Is there any way i can do this
any help is appreciated
Regards
Chattarbir Singh
2 Replies Last Post 2010/02/08 19:51 JST
Posted: 2 decades ago 2010/02/08 17:30 JST
AS such I see onloy two ways, interesting suggestion to push onto COMSOL support too.
1) you make your COMSOL plot aand you export the data as a text file or M file and use Excel or matlab to finish
2) I could still believe if you make a piecevise function from your experimental data, and select "kep plot" once plottet the COMSOl data, then you attempt a "plot function" I do not know if it works, but its easy to try (I'm far from my licence these days, cannot check myself ;)
Hi AS such I see onloy two ways, interesting suggestion to push onto COMSOL support too. 1) you make your COMSOL plot aand you export the data as a text file or M file and use Excel or matlab to finish 2) I could still believe if you make a piecevise function from your experimental data, and select "kep plot" once plottet the COMSOl data, then you attempt a "plot function" I do not know if it works, but its easy to try (I'm far from my licence these days, cannot check myself ;) Good luck Ivar
Posted: 2 decades ago 2010/02/08 19:51 JST
Hi IVOR
Thank you for the suggestion. With peice wise function i was not able to make it .
But by making scalar expression i was still able to plot them
Kind regards
Chattarbir Singh
Hi IVOR Thank you for the suggestion. With peice wise function i was not able to make it . But by making scalar expression i was still able to plot them Kind regards Chattarbir Singh
