Getting 2-D geometry from 3D object
I am running a mode propagation analysis of a waveguide so need to run a set of 2-D mode solvers along the propagation direction. I am wondering is it possible to get 2-D gemetry of the 3-D waveguide cross-section in comsol automatically? I have gone through almost everything in the helpfile and it seems usually comsol use 2-D to build 3-D geom but not the other way around.
I would greatly appreciate your answers.
regards,
Max
2 Replies Last Post 2012/08/10 6:41 JST
Posted: 1 decade ago 2012/08/09 22:08 JST
Unfortunately, no, from my knowledge, and I'm missing badly that functionality too.
What you can do is to define a 2D workplane for a 3D volume and then you get the projection shadow lines, but you need to overwrite/paint your geometry over the shadow lines. Your "pick" magnet points are still given via the projected cut geometry, so COMSOL has 90% of the info to create the intersection, but it does not finalise the 3D to 2D projection functionality, unfortunately, and so far ...
Hi Unfortunately, no, from my knowledge, and I'm missing badly that functionality too. What you can do is to define a 2D workplane for a 3D volume and then you get the projection shadow lines, but you need to overwrite/paint your geometry over the shadow lines. Your "pick" magnet points are still given via the projected cut geometry, so COMSOL has 90% of the info to create the intersection, but it does not finalise the 3D to 2D projection functionality, unfortunately, and so far ... -- Good luck Ivar
Posted: 1 decade ago 2012/08/10 6:41 JST
Thanks for reply. I will do that in solidworks then.
Max
Thanks for reply. I will do that in solidworks then. Regards, Max
