Help Comsol5.5
Posted 2022/07/14 17:30 JST Modeling Workflow, Fuel Cells & Electrolyzers Version 5.5 1 Reply
No variable is defined. - variable: comp1.rf2.pA - geometry: geom1 - region: 1 Failed to evaluate variable. - variable: comp1.tcs2.pmtcs1.minput_pressure - Defined as: comp1.rf2.pA Failed to evaluate variable. - variable: comp1.tcs2.pA - Defined as: comp1.tcs2.pmtcs1.minput_pressure Failed to evaluate variable. - variable: comp1.tcs2.rho - Defined as: (comp1.tcs2.pAcomp1.tcs2.Mn)/(R_constmax(eps,comp1.tcs2.T)) Failed to evaluate variable。 - variable: comp1.tcs2.c_wH2 - Defined as: (comp1.tcs2.wr_wH2comp1.tcs2.rho)/comp1.tcs2.M_wH2 Failed to evaluate variable。 - variable: comp1.cd.iloc_per1 - Defined as: i0_a(((comp1.tcs2.c_wH2exp(((comp1.cd.alphaa_per1F_const)(comp1.cd.Ect-Eeq_a))/(R_constcomp1.cd.pce1.per1.minput_temperature)))/c_h2ref)-((comp1.tcs2.c_wH2O_aexp(((comp1.cd.Ect-Eeq_a)(F_const(-(2-comp1.cd.alphaa_per1))))/(R_constcomp1.cd.pce1.per1.minput_temperature)))/c_h2oref)) Failed to evaluate variable. - variable: comp1.cd.iv_per1 - Defined as: comp1.cd.Av_pce1_per1comp1.cd.iloc_per1 Failed to evaluate variable. - variable: comp1.cd.ivtot - Defined as: comp1.cd.iv_per1 Failed to evaluate the evaluation expression. - expression: comp1.cd.ivtotdvol_spatial A Jacobian matrix that failed to evaluate an expression. - expression: (comp1.cd.Ilxtest(comp1.philx)+comp1.cd.Ilytest(comp1.phily)+comp1.cd.Ilztest(comp1.philz)+comp1.cd.ivtottest(comp1.phil))*(dvol_spatial)
