Meshextend error : "Cannot convert to int"
I tried to adapt the model "Generator sector dynamic" to my model (synchronous generator with magnets).
I program with Matlab and when I launch my program, everything seems fine until the call to the function "meshextend" and follows this error message:
?? Java exception occurred:
Exception:
com.femlab.jni.FlNativeException: Cannot convert to int
ElemTree syntax error
- Name: elgpspec
Now, I cannot really upload here the whole MATLAB code, so I'm not expecting any precise debugging help, but if someone could give me some ideas and things to check, that would be nice.
Ronan
1 Reply Last Post 2010/02/12 5:27 JST
Posted: 2 decades ago 2010/02/12 5:27 JST
I now did the same but with COMSOL only (after having exported the geometry through MATLAB and imported into COMSOL).
I followed exactly the step given in "Generator Sector Dynamic" but adapted to my geometry. So, for example, I didn't set any antisymmetry nor periodic point condictions.
When I try to solve it, I get the following error:
Error: 6170
Failed to evaluate variable.
- Variable: F_torquez_emqa
- Global scope
- Expression: F_torquez_emqa
Even though I didn't forget, to generate variables for the force and torque, as described in the documentation of "Generator Sector Dynamic".
Attached is the mph file. Thanks for your help!
I now did the same but with COMSOL only (after having exported the geometry through MATLAB and imported into COMSOL). I followed exactly the step given in "Generator Sector Dynamic" but adapted to my geometry. So, for example, I didn't set any antisymmetry nor periodic point condictions. When I try to solve it, I get the following error: Error: 6170 Failed to evaluate variable. - Variable: F_torquez_emqa - Global scope Failed to evaluate expression. - Expression: F_torquez_emqa Even though I didn't forget, to generate variables for the force and torque, as described in the documentation of "Generator Sector Dynamic". Attached is the mph file. Thanks for your help!
