Johnson Cook
Hi!
Is there a possibility to implement a Johnson Cook Material model (hardening function dependent on Temperature, strain and strain rate) in the nonlinear structural mechanics module?
I have not found an "effective strain rate" variable to do it myself. Does somebody have an example model for this purpose?
Thank you very much!
1 Reply Last Post 2012/08/28 5:27 JST
Posted: 1 decade ago 2012/08/28 5:27 JST
Hi Hendrik,
I have implemented something similar for viscoplastic materials models so I believe a Johnson Cook model can be user implemented in COMSOL. You should define the effective strain rate based on the individual plastic strain components then add a global variable for the time integral of this strain rate.
Check out also the COMSOL example titled “Viscoplastic creep in Solder Joints” which implements an Anand material model. You should look at that example prior to Version 4.3 since COMSOL now has the Anand model built-in.
Nagi Elabbasi
Veryst Engineering
Hi Hendrik, I have implemented something similar for viscoplastic materials models so I believe a Johnson Cook model can be user implemented in COMSOL. You should define the effective strain rate based on the individual plastic strain components then add a global variable for the time integral of this strain rate. Check out also the COMSOL example titled “Viscoplastic creep in Solder Joints” which implements an Anand material model. You should look at that example prior to Version 4.3 since COMSOL now has the Anand model built-in. Nagi Elabbasi Veryst Engineering
