Urgent please: Rotating results with the geometry
Posted 2022/08/27 17:46 GMT-4 Heat Transfer, Geometry, Studies & Solvers 0 Replies
I am doing a simulation of a cylinder between two walls (As shown in the picture attached). I divided my simulation into two studies. The process are as follow: 1. study 1 (time dependent) the cylinder is at position 1. 2. After computing study 1 I rotate the cylinder 60 deg using rotate geometry object. 3. computing study 2 (time dependent) the cylinder is at position 2 and using the last values of study 1 as initial value for study 2. The problem is that the initial values of study 2 are the values where the cylinder is at position1 however what is needed is to rotate the last value of study 1 with rotating the position of the cylinder. Any suggestion will be appreciated.
Hello Omar Osman
