How to calculate effective dielectric constant?
Greetings to all,
I have recently started using COMSOL to simulate a system from which I want to calculate the effective dielectric constant. I contruct the system as follows:
  1. I generate a "bulk" material_1 (rectangular shape)
  2. I generate N circles to represent particles of material_2; unite these circles (dont keep input objects nor interior boundaries)
  3. I make the difference between material_1 and material_2 systems, keeping both input objects and interior boundaries;
  4. On electrostatics physics I set the lower edge of material_1 to be ground and upper edge to be the electric potential;
At this point, from this construction I want to calculate mostly the effective dielectric constant, but if I can calculate effective resistivity and piezoelectric constant would be great as well. I do my simulations on Static solver but I also tried Frequency domain (1 kHz to 1 MHz) and the results do not change. Moreover, for such simulations I have already done their experimental counterparts so I know what to expect.
How do I calculate the effective dielectric constant and my simulations appear to be incorrect?
VR
1 Reply Last Post 2022/09/20 22:53 JST
Jeff Hiller COMSOL Employee
Posted: 3 years ago 2022/09/20 22:53 JST
Hello Victor,
See this model which involves a different physical phenomenon but basically the same equation.
Note that in 2D your circles correspond to cylinders. Not sure whether that's the shape you intend for your particles, but I thought I'd mention it. If you intend to model spherical particles, then a 3D model is in order.
Jeff Hiller
Hello Victor, See [this model](https://www.comsol.com/model/effective-diffusivity-in-porous-materials-978) which involves a different physical phenomenon but basically the same equation. Note that in 2D your circles correspond to cylinders. Not sure whether that's the shape you intend for your particles, but I thought I'd mention it. If you intend to model spherical particles, then a 3D model is in order. Best, Jeff
