Discretization schemes, micromixer tutorial
Dear Comsol users,
I kindly ask you to help me with the following task. I have to specify the discretization schemes employed in my model. Since I used an existing tutorial model 'micromixer.mphbin' and did not change any of the tutorial's solver procedures could you please help me specify/identify the discretization schemes employed?
I tried to get this information from the tutorial's pdf (under 'Study 1' section) though unsuccessfully.
Thank you very much for your help,
best regrads!
3 Replies Last Post 2012/09/11 23:06 JST
Posted: 1 decade ago 2012/09/07 2:35 JST
is the polynomial discretizatio of te elements you are inteested in ?
If so you need to ensure yiu have enabled the advanced nodes and the discretzation ones, to see them => options preferences ... tab
Hi is the polynomial discretizatio of te elements you are inteested in ? If so you need to ensure yiu have enabled the advanced nodes and the discretzation ones, to see them => options preferences ... tab -- Good luck Ivar
Posted: 1 decade ago 2012/09/11 19:32 JST
Hello Ivar!
Thank you for your response. I have additional question; under the 'Discretization' node for Laminar flow node the following notations are possible:
- P1 + P1
- P2 + P1
- P3 + P2
Can anybody explain me what do this definitions stand for?
Thank you very much for help!
Hello Ivar! Thank you for your response. I have additional question; under the 'Discretization' node for Laminar flow node the following notations are possible: - P1 + P1 - P2 + P1 - P3 + P2 Can anybody explain me what do this definitions stand for? Thank you very much for help!
Posted: 1 decade ago 2012/09/11 23:06 JST
Hi again!
I found the answer to what I was looking for on the forum:
www.comsol.com/community/forums/general/thread/20434/
P1+P1 is first order elements for velocity and first order elements for pressure
P2+P1 is second order elements for velocity and first order elements for pressure
P3+P2 is third order for velocity and second order for pressure
Thanks everybody!
Hi again! I found the answer to what I was looking for on the forum: http://www.comsol.com/community/forums/general/thread/20434/ P1+P1 is first order elements for velocity and first order elements for pressure P2+P1 is second order elements for velocity and first order elements for pressure P3+P2 is third order for velocity and second order for pressure Thanks everybody!
