transmittance setting problem
Posted 2012/09/06 19:41 GMT-4 Version 4.2a 4 Replies
I have used comsol to simulate transmittance of a structure. And I have used two methodd to calculate transmittance. The first method is integration the input port and output port and then dividing then. But it is not a good method because of there is some reflection existing that would influence the result(although I set PML in the in the input side and output side). And the other method is that I set all the material of the structure to be air and then integrate the input boundary. And then I use this integration value as the input value of my structure. the material of input side is air so I think the latter one is a good method. I have tried many structure and they all work well except one structure I just simulated and found that the transmittance is bigger than 1. I don't know what the problem with my second method. I wonder if it is right.
Thank you.
Thank you.
4 Replies Last Post 2012/09/07 14:00 GMT-4
