Cumulative sum ???
Is it possible to achieve (within comsol) a cumulative sum of a time varying data. Here I'm interested in the calculation of the cumulate mass of water going through a porous media. It is quite easy to get the transient evolution of mass flow rate, but I do not manage to get the cumulative mass flow unless exporting data to Matlab.
Any sugestions are welcome.
D. L.
1 Reply Last Post 2012/09/11 6:32 JST
Posted: 1 decade ago 2012/09/11 6:32 JST
what about adding an equation and dependent variable that you integrate over time via COMSOL equation solver ?
There is something about that in the KB (knowledge base, try a search, and on the Forum)
Or you dump your results into a table and apply a sum (lower options of the talbe tab)
Hi what about adding an equation and dependent variable that you integrate over time via COMSOL equation solver ? There is something about that in the KB (knowledge base, try a search, and on the Forum) Or you dump your results into a table and apply a sum (lower options of the talbe tab) -- Good luck Ivar
